Trust you tester / meter?
Discussion in 'General Electronics Chat' started by Gdrumm, Sep 29, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I'm delving into antique radio repair as another hobby, and one of my first ones is a shortwave Spartan 6A66. I've replaced all the caps, except for the Filter Cap, which I finally figured out how to re-stuff this weekend.
    I bought an old vacuum tube tester from ebay, and all of the tubes except for one are testing bad.
    I believe they are 7 pin (larger fatter tubes, like 35z5gt, 35l6gt, 12sq7gt, 12sk7gt).
    On my 3 other old AM radios, I tested all the tubes (I believe they are 9 pin) (smaller tubes), and they all tested good.
    Should I trust the tube tester?
    Is there a way to test the tubes with a multimeter?
    Thanks,
    Gary
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    the only test on tubes with a multimeter is to test for a filament contnuity. possably measure viltage in set under power, thats about it. most multimeters dont have enough voltage to test for gas or conduction.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Not really easy with a meter unless you set up certain test voltages.
    Way- way back I built my own tube tester, even wound the transformer to cover all the different filament voltages!
    I still have the copy of Radio Valve Data that covered the characteristics of 7000 tube types. (UK 9/6d).
    Most tube testers should give you a ball park figure, like anything probably some are better than others.
    They must be getting rare now though?
    Max.
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    As said, you can check if the filament is OK.
    Also you could check for shorts between the elements in the tube (cathode, grid, anode).
    Here is a page that might interest you:
    http://www.nj7p.org/
    You will find a lot of tube data over there.
    Bertus
    Gdrumm likes this.
  5. #12
    Nov 30, 2010
    16,665
    7,310
    I quit trusting tube testers when a peanut size RF amplifier tested good with a crack in the glass and the getter gone all white.
    Just swapping out the tube was the gold standard from 1950 to 1970, but that isn't so easy in the 21st century.
    Now, you need to understand what each tube is supposed to do and check to see if it's doing it.
    Easier said than done! Just trying to measure the circuits with a 10pf probe will throw some of them off.
    SgtWookie likes this.
  6. Kermit2
    Feb 5, 2010
    3,845
    963
    you can use your meter to check all those old carbon resistors. Replacement of those might be needed. They drift off value quite a bit. The female pins in the tube sockets could probably use a good cleaning as well.
  7. RichardO
    May 4, 2013
    1,335
    429
    Excellent idea. I would clean the contacts in both the radio and the tube tester.
  8. Gdrumm
    Aug 29, 2008
    684
    36
    Good thoughts, and cleaning might make a big difference.
    Awesome Tube lookup link as well.
    And for the other tips,
    Thanks all,
    Gary
  9. #12
    Nov 30, 2010
    16,665
    7,310
    Gdrumm likes this.
  10. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Largest tube I have worked with had a 3Kw cathode htr.
    Max.
  11. #12
    Nov 30, 2010
    16,665
    7,310
    Canada is a good place to work on 3KW tube heaters. You can comfortably heat the room with them! :p
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Actually it was in the UK, H.F. 450Khz equipment, silver soldered the filler pipes in the Austin/Morris Mini gas tanks.:cool:
    Max.
    #12 likes this.
