Its a Chinese inverter, i am very satisfied with it expect that it got the buzzing noise problem, i got 3 laptops running on it and 2 led screens that i don't want to damage.I think it's not a good design. I don't know if it will hurt your computer. Who made it?
I got a 600W wind turbine and a 600 Ah battery bank so i use the inverter with that setup, i will try the capacitor and see where it goes from there. but i wish some one could answer my question about if this interferance would cause any damage to the devices that i am running ?
Regarding the weight of the inverter, it weighs 3kg and its a 1000W
If the equipment is audio, I don't think it will have a damaging effect, but I'll be cautious to use it on sensitive digital processing equipment such as computers.
Do you have an earthed (grounded) neutral on your inverter?
In most cases, it is a requirement that the output "neutral" should be grounded, mostly for protection purposes, but it might help in your case. Please give us feedback on this also.All the stuff running on the inverter is electronics 3 computers and 2 LED screens.
the inverter is not grounded but if that makes a difference i will for sure give it a try.
Don't go over a couple hundred nF, or else you'll have a lot of surge current. If things improve, you might want to go back and try a L-C filter.i will try the capacitor and see where it goes from there.
NoAre you saying the noise is gone when you use a capacitor filter AND ground the neutral wire?
Exactly, and when one of the conductors of the output line cord is connected to ground, you effectively get the shielding effect due to its close proximity to the live conductor.There are two ways to make a sinewave output inverter. One is linear - with a true analog sinewave into a power amplifier into the primary of a step-up transformer. The other is switching - a pulse width modulated squarewave into the primary of a step up transformer. Sounds like you have the latter, and are hearing a beat frequency from the PWM. Depending on exactly where the EMI source is, a shielded line cord might help.
ak
