Troubleshooting
Discussion in 'General Electronics Chat' started by RG23, Aug 22, 2012.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I need to build strong troubleshooting skills
    given an electronic circuit and to find the defect what precise steps need to be taken
    do you really need to know the function of each and every component
    For instance at present when I look at a circuit I am not sure what the capacitor, resistor or transistor etc is actually performing which function.
    Did any of you have the same issue and then became proficient in troubleshooting?
  2. cork_ie
    Member
    Oct 8, 2011
    348
    58
    I would start by becoming familiar with power supplies both transformer and SMPS types. How they work and how to test.
    It makes subsequent fault finding easier as overloads or no loads in subsequent stages become easier to identify.
  3. panic mode
    Oct 10, 2011
    1,328
    305
    first learn how components operate in general then try to understand what circuit does or how it operates.
  4. #12
    Nov 30, 2010
    16,656
    7,296
    First, understand the theory of the circuit you are working on, only then will your measurements make sense. Measuring a voltage or current without knowing what to expect is useless.
