Hey guys, would greatly appreciate a little bit of help to figure out why my TMR0 isn't working to my desire. First off the general idea of my design is to make a frequency counter. i.e. How many rising edge (positive) pulses happen on T0CKI over a certain period. I am using a PIC18F4520 /w 20MHz HS osc. Of course an LCD as a display. Using MPLAB v8.83 and C18. I've been trying to learn interrupts for a while now. Looking for a few pointers. Right now I basically have it set up to display a 1 on the Lcd when and if the TMR0 overflows. Here is my relevant code:
Rich (BB code):
#include <p18f4520.h>
#include <string.h>
#include "main.h"
#include "messages.h"
/*************DEFINE*************/
#define TRISDATA TRISD
#define PORTDATA PORTD
#define TRISFUNCTION TRISC
#define RS LATCbits.LATC6
#define E LATCbits.LATC7
//#define RW NULL
/***********INTERRUPTS***********/
volatile int count = 0;
void low_isr(void);
#pragma code low_vector=0x18
void interrupt_at_low_vector(void)
_asm GOTO low_isr _endasm
#pragma code
#pragma interruptlow low_isr
void low_isr (void)
if(INTCONbits.TMR0IF == 1)
INTCONbits.TMR0IF = 0x00;
count++;
else
/**********MAIN SECTION**********/
void main(void)
Initialize();
TRISA = 0;
TRISAbits.RA4 = 1;
Command(0b00000001); //clear display
Command(0b00111000); //function set
Command(0b00001111); //display control
T0CON = 0b11100000; //Config T0
INTCONbits.GIE = 1;
RCONbits.IPEN = 1;
for(;;)
Message(Overflow); //Print message to LCD
Command(0b11000000); //goto second line
if(count == 1)
WriteChar('1'); //Write 1 to LCD if the timer EVER overflows
DLY_S(5);
else
Message(Times); //Print message to LCD
DLY_MS(500);
