Troubleshooting CM8870 DTMF Decoder Circuit
Discussion in 'The Projects Forum' started by techadiya, Jan 11, 2013.
  1. techadiya
    Jan 4, 2013
    I'm trying to build a DTMF decoder using the CM8870 DTMF decoder IC. I made the project on a breadboard. But the decoding never works!! On powerup, it displays a random BCD output on it's 5 output pins. And then that Outputs stays high till I turn the power off. I used the exact circuit here + a few more decoupling capacitors too.
    I'm dead sure about the connections of the circuit. And the clock ( 3.579545 MHz ) is working fine too.. What maybe the problem here? Anybody could help?
  2. eblc1388
    Nov 28, 2008
    1,542
    102
    The circuit looks fine, as it is the same one taken straight from the data sheet.
    You can do the following checks:
    a. check that pin 4 is approximately half the supply voltage
    b. increase the resistor between pin#2 and pin#3(not the one connects to 100nF) from 100K to 220k, 330K or 470K. This increases the input gain from 1 to 2.2, 3.3 or 4.7 to suit your input signal strength.
  3. techadiya
    Jan 4, 2013
    Thank You! Increasing the value of GS resistor solved the problem.. :) Now it's a 300K resistor.. :) :)
  4. suranisahil786
    Mar 11, 2013
    techadiya can you please send me encode circuit of dtmf at <SNIP>
  5. gerty
    Aug 30, 2007
    1,154
    304
    Why not share it with everyone else!
  6. sagarjagyasi
    Aug 23, 2013
  7. rogs
    Aug 28, 2009
    279
    37
  8. techadiya
    Jan 4, 2013
  9. gauravpwr8
    Feb 13, 2014
    techadiya can you please send me the working circuit for dtmf decoding with all the issues resolved.
