Troubleshooting an Industrial Motor Driver
Discussion in 'Technical Repair' started by Dritech, Jul 29, 2016.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I have a damaged Kollmorgen S200 series servo motor driver that I wish to repair. I did some search on the net, but found no schematic of the driver.
    Is it possible to troubleshoot such device without a schematic if no damaged companents are visible? Any clues of what I can do to make it work?
    Thanks in advance.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Well you would have to identify the sub circuits and know their intended functions/inputs/outputs,etc.. if nothing is visibly damaged..
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    That is a very sophisticated drive with firmware processors, unless the fault is in the power output section components, you may have a problem.
    Max.
