trouble with poles and zeros
Discussion in 'Homework Help' started by suzuki, Oct 2, 2012.
  1. suzuki
    Aug 10, 2011
    119
    I have a transfer function in the s-domain that looks like
    TF = \frac{e^{\frac{-s}{25000}(s+2)}}{(s+9)}
    I'm having trouble determining what is the meaning of the term e^{\frac{-s}{25000}. Is this a zero?
    Furthermore, I can't quite get a grasp on how I would plot this in MATLAB using the transfer function call.
    Any and all suggestions are appreciated.
    tia
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It's a transport delay term - or pure time delay in time domain. One approach in analysis is to approximate the pure delay term with a function such as the Pade approximation.
    suzuki likes this.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Check the attachment ...
    suzuki likes this.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The effective dead time in your TF is quite small - the order of 40uS. I doubt this is going to have any significance given your pole & zero are at quite low frequencies. I'd need to check with some actual plots however before saying that the dead time could be ignored in an analysis when this system was used in a closed loop feedback control case.
    An additional problem when using the Pade approximation is deciding whether the resulting closed loop behavior truly reflects the case when pure dead time is the reality.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    I had a go at using a 4th order Pade approximation type R(n-1),Rn(s) with T=40usec as the pure delay approximation in your TF.
    The open loop gain margin for the TF is -0.68dB and the phase margin -149.6°. This suggests an unstable system would result with a case of simple closed loop unity feedback. This was confirmed by plotting the closed loop response.
    Just goes to show one can't make any generalizations without undertaking a careful analysis.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Can a system be unstable with loop gain<1?
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes - I know conventions can often be a distraction. In the software I use, a negative gain or phase margin in the open loop transfer function bode plot indicates the likelihood of an instability in direct [-ve] feedback closed loop operation. A positive value in both cases [gain & phase margin] would normally indicate a conditionally stable case in the aforementioned closed loop operation.
    So a gain margin of -0.68dB [as I quoted] means the gain is 0.68dB above 0dB at the open loop transfer function -180° phase transition point.
    Hope that makes sense.
