Hey guys,
Still in the same boat.. any other ideas?
Thanks!
Thanks!
Hey man,
Well I wired it up this way, and am now using a regular LED per your suggestion. The LED lights up and stays on when connected to the 4.5v batteries and is off when the batteries are removed from the circuit. So, I now have:
LED + --> 22 Ω --> +
LED - --> C of Transistor --> -
B of transistor --> 1k Ω --> +
E of transistor --> -
I need the IR LED to come on only when given a signal from TX. Am I missing something?
Please pardon my ignorance. I am somewhat new at wiring, and I know this might be a noob question but I don't understand what the "TX" means. I wire things to + or -. I don't understand exactly what you mean when you say "input a signal to the base." I know you mean the base of the transistor, but I don't know what that means in terms of what it gets wired to.The reason the leds stay on is because your 1K is hooked to positive side battery.
Remove the 1K from the battery.
Then you input a signal to the base to turn it on.
Build your circuit just like the schematic in the first post.
Hey,Hi,
Noob questions are always welcomed,
if a person has to apologize for asking newbie questions, then what's the use of this forum anyhow.
This forum is for just that, to help others in answering the best they can ,any question sincerely asked by another...
I don't know where you got your schematic from so I don't know what the TX stands for, but I do know what the schematic is showing, by the configuration of the circuit.
The circuit is designed as a switch, to turn the LED on when a positive voltage is applied to the resistor marked TX.
As TX is left open, as shown in the original schem. then no current flows thru the transistor, thereby the LED is off.
When you apply a positive signal voltage to the TX resistor the transistor will conduct current to flow thru the LED.
So TX could be driven by any circuit that has a positive voltage output,
Again TX is just the name this designer gave for that term.
as it refers to his overall circuit.
Hey,Hi Mark,
Please, give us as much background as possible concerning what your teacher wants you to do with this project.
What is the function of it, what device is going to be hooked up to it, so we have an idea of how to implement circuit values.
OK, so Battery GND -> output jack GNDI didn't realize you had the availability of a output jack from your phone,
This makes it a lot easier to work with so then,
Instead of connecting the neg. terminals of both batteries, as I shown in the schems. it is better to connect your circuit neg. battery term. to the output jack ground term. and then connect the capacitor, to the signal term. of that output jack.
If you have a multimeter, with a continuity tester, you can determine what the ground side is on your headphone jack, by touching a probe to one of the jack pins, (if you have acces to it, and to the ground terminal on the phone device.
That;s the usual way of connecting 2 circuits together with a common ground, when and OUTPUT JACK is available.
That way there is no direct soldering wires to the phone batteries and all direct conections are made at the jack only.
That's how I coupled my portable CD player to my led display (primitive volume meter) circuit.
I used the output speaker jack and connected my circuit neg. to the ground term. of the CD jack, and then coupled the signal pin of the CD jack to a capacitor to the input of my circuit.
Like this.
I just built that 3rd circuit on the earlier post.
I used my osciloscope to check the frequencies of a square wave.
I set my power supply to a min. value of 4v.DC
I set my frequency generator to a squatrewave from 100Hz. to 100Khz.
I used a visible LED (green), it's voltage drop showed 1.8v. to full lighting.
for every freq. from 100hz up, the input voltage of the quarewave, had to be at around 2.8v.peek. in order for the LED to turn on.
anything lower than 2.8v, coming from the generator the LED remained off.
So depending on the vout from your phone signal will determine if the circuit will work for this application.
Otherwise different values for resistors and even power supply will need to be implemented.
Hi,About to head to Radio Shack to get all of these parts. I guess I will test this circuit today.
Does it have a chance of working with a 940nm IR LED?
Also, I wanted to ask if it was cool with you to give you credit for all your help with this project. In the application's about / credits screen I have included your username for the circuit schematic.
Let me know if you're cool with that!
-Mark
by Duane Benson
by Aaron Carman
by Aaron Carman
by Don Wilcher
