Trouble with complex power
Discussion in 'Homework Help' started by db21, Feb 22, 2016.
  1. db21
    Feb 22, 2016
    10
    Hey, I'm seriously stuck on my homework regarding complex power. I'm at a loss for what to do. These are the two problems:
    1. Calculate the complex power for a resistor, R=10Ohms that has a current of i(t)=14,1*cos(314t-45°) running through.
    2. Calculate the complex power for a condensator, C= uF which has a voltage of v(t) = 14,1*cos(1000t+45°).
    I know that the complex power can be found by multiplying the RMS voltage and the complex conjugate of the current i, but I'm struggling. Any help is greatly appreciated. Thanks a lot!
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You have mentioned one way to calculate power, but using Ohm's Law and a bit of algebra you can find two additional expressions. One of the expressions involves just current and impedance, and the other involves just voltage and impedance.
  3. db21
    Feb 22, 2016
    10
    Thank you for your response :). I'm not entirely sure what you mean. Are you suggesting just I^2*R?. Thanks a bunch.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Two out of three is not bad. The third should be a piece of cake.
  5. db21
    Feb 22, 2016
    10
    I'm puzzled. i(t)=(14,1*cos(314t-45°) )^2 * 10 Ohms?
    Edit: The rules for complex power are different, no?
  6. db21
    Feb 22, 2016
    10
    Could I find v(t) from R and I and then use those two to get P? Is that what you were suggesting?
  7. db21
    Feb 22, 2016
    10
    My best bet atm is convert the current to a phasor and multiply that with the resistor. Convert the result back to "normal" and multiply with the current?
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    How can that be i(t)?
    Track your units!!!
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    If you are given the current in a resistor can you find the voltage across it?
    If you are given the voltage across a capacitor can you find the current through it?
    If you know the voltage across a device and the current through a device, can you find the complex power in the device?
  10. db21
    Feb 22, 2016
    10
    So first up is finding the voltage across it and then using that to find the complex power in the device :)
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    Finding the voltage across and the current through -- you need both. That's the most fundamental way and will always work. There are shortcuts that will work in specific instances, including these, because of what you know, for instance, about the reactive power in a resistor and the real power in a capacitor.
  12. db21
    Feb 22, 2016
    10
    So you're telling me there is a short cut?
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    Yes -- but shortcuts are best taken only when you understand the fundamentals well enough to see the shortcut on your own. So focus on the fundamentals first.
  14. db21
    Feb 22, 2016
    10
    Of course. Couldn't I just do S=I^2*Z. So for this example it would be (14,1A)^2*10Ohms, or is that completely wrong :)?
  15. WBahn
    Mar 31, 2012
    18,087
    4,917
    Yes, you can do that.
    Do you know where that S=I²·Z formula comes from? Can you derive it? Or is it just a formula on a sheet that you grab and use.
    I ask because, if it's the latter, then there's a good chance that you will get the next one wrong.
  16. db21
    Feb 22, 2016
    10
    As I understand it as and I've read in my book it is based on the following:
    "In a linear circuit the sum of the complex powers produced by all the sources is equal to the sum of the complex powers delivered to all of the passive loads."
    You are right about the next one tho :). I can't figure out where to start.
  17. WBahn
    Mar 31, 2012
    18,087
    4,917
    While this is true, it has no bearing on the formulas you are trying to work with.
    So it's time to take a step back and get the fundamentals under your belt. The following might help:
    http://forum.allaboutcircuits.com/blog/complex-power.580/
  18. db21
    Feb 22, 2016
    10
