Trouble with 4-wire measurement
Discussion in 'General Electronics Chat' started by fhernandezx3fh, Jun 10, 2008.
  1. fhernandezx3fh
    Jun 10, 2008
    All,
    Hi everyone, I just joined the forum but I've been visiting this site for a while now. It helped solidify some of the concepts learned in school. There is something that I am not able to grasp when talking about 4-wire resistance measurements. With 2-wire measurements, the DMM acts as a constant current source then measures the voltage drop, thus calculating the resistance. With 4-wire measurement why isn't the resistance of the sense lines an issue.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    The two methods are fundimentally identical, but the 4 wire measures the voltage from the current regulator at the resistor, thus eliminating a potential error source, the resistance of the leads themselves. If you have 6 digits or more of accuracy it matters quite a bit. Industry does actually have such meters, and uses them in a routine basis.
  4. John Luciani
    Apr 3, 2007
    477
    Because the current is zero (or close to it) through the sense lines.
    0 * Rsense = 0V drop
    (* jcl *)
