Trouble shooting circuit
Discussion in 'Wireless & RF Design' started by nerdegutta, Oct 31, 2010.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    I've tried to make a tv/video transmitter circuit, short range. So I googled around and found a circuit, and modified it a bit/removed the audio part.
    See thread:
    http://forum.allaboutcircuits.com/showthread.php?t=33002
    So now I have this, see attached files.
    Problem is... It doesn't work. So far, I found that it's frequency is about 3.1-4.0 MHz. I just don't get it. Guess you guys see the problem in the schematic right away.
    In the three open holes, I've put the pot.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    are u sure u don't have solder bridges?
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    I'm quite sure I don't have solder bridges. That's one of the first things I check.
    But I cannot be to sure enough, I'll check again....
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Try pulling the inductor apart a bit more and post how much the frequency changes.
    Adjusting it's value/length may get enough change in. If it doesn't change much, then something else is wrong.
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    The traces are quite long for the intended frequency.
    Are you really using a BC547 as transistor?
    That is a universal transistor and not a real RF transistor like the BF199 or equal types.
    Bertus
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes, I'm using the BC547. Maybe I should change to another. What do you suggest, I don't think I have the BF199.
    So you think the traces are too long... Hmm... Thought I put the components close together.
    Is the schematic OK?
  7. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thank you.
    I will try to build the one in post #3, changing the NPN's to something similar I got.
    Anyway. The schematic I postet, shouldn't it work. In theory?
  9. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    In theory it should work.
    I only have some doubts about the used transistor.
    Bertus
  10. nerdegutta
    Dec 15, 2009
    2,565
    805
    Just got mail from my local dealer. (Maybe supplier is a better word... :))
    I will buy a couple of:
    2N2907A
    BF199
    I saw the long list of transistors in another tread, so I sent him the list. All he had was these... Anyway, looking forward to some quality time at the lab.... :D
    Thanks.
