Trouble analyzing circuit
Discussion in 'General Electronics Chat' started by giv know, Jan 10, 2015.
  1. giv know
    Jan 10, 2015
    I have the following problems understanding the above circuit:
    • I understand the part where the optocoupler activates transistor T3 acting as a relay driver. I also understand that this would activate relay RL1. But how does relay RL(a) get activated to N/O?
    • Also, when the relay is in the N/C position, how does power from the 12V SMF battery get to the output?
    • The NAND gate N1 has both inputs at the same value. When the ac mains is working, wouldn't the NAND give 0 as output where as it should actually be giving 1?
    Note: This circuit can be found at http://bestengineeringprojects.com/electronics-projects/advance-mini-ups/ along with an explanation. I can not make sense of the explainaion, hence this post.
  2. ericgibbs
    Jan 29, 2010
    2,590
    389
    hi,
    Look at this marked up diagram, the Red arrows and text are for mains ON.
    E
  3. giv know
    Jan 10, 2015
    The labeled diagram is quite helpful. Thanks Eric!
    Could you confirm if its safe to conclude that once RL1 gets energized, all 4 of its contact sets switch to N/O.
  4. ericgibbs
    Jan 29, 2010
    2,590
    389
    hi giv,
    Yes, the relay has 4 pole change over, sets of contacts.
    N/O = Normally Open, N/C = Normally Closed, this is when the relay is not energised == Off.
    So all the N/O contacts are closed, when the relay is energised.
    E
