Depends on what they are for. All the snowboarding trophies have to be returned.can I keep the trophies on my trophy cabinet?
Some things can't be compensated with pointsNor are the 30 points for 8 years of marriage being awarded, apparently.
John
Yup, I plan to use my AAC trophy points to supplement some of my expenses when I retire. If I put enough effort into AAC between now and retirement, some modeling shows that my $3.29 Starbucks will only cost me $3.29.As a point of interest (Re: promotions) it seems that, once upon a time, 200 counted posts qualified as 'senior' -- Inasmuch as promotion is tied to trophy points, 5000 counted posts appear to be the current trigger -- Kewl how these fora mirror 'real life' as regards the ever increasing retirement age!
Best regards
HP
So, what are trophy points worth on ebay?Yup, I plan to use my AAC trophy points to supplement some of my expenses when I retire. If I put enough effort into AAC between now and retirement, some modeling shows that my $3.29 Starbucks will only cost me $3.29.
Why must we have seen it? You tagged me and that's why I'm seeing it now. Sorry if you feel that's somehow discourteous.HP I searched for subject of 2500 posts and found out it is documented bug for almost two years! See here
http://forum.allaboutcircuits.com/threads/error-in-trophy-point-calculations.103684/
Also @WBahn said exact same concern as you about little bugs can mean bigger problems. So @WBahn and @bertus know all about it but they don't say anything on your thread here which they must have seen! HP I say you have right to expect better courtesy than that!
Simple -- I don't have the access to look into it and the people that do don't care enough to do so.
Wondering the above myself too.I'm not sure why trophy points exist, but whatever.
No, they are not manually counted, they are automatically calculated.Hi HP,
I am sure you are kidding. There all lots of errors in the Trophy Points. I don't attribute that to any favoritism. I suspect they are manually counted and awarded whenever someone gets the time to look at them or when a member raises a question. The update interval seems at best to be irregular. You will be fixed soon.
Regards,
John
If you are paying that much for coffee, you "don't need no stinkin'" trophy points.Yup, I plan to use my AAC trophy points to supplement some of my expenses when I retire. If I put enough effort into AAC between now and retirement, some modeling shows that my $3.29 Starbucks will only cost me $3.29.
Or rather, they are automatically miscalculated.No, they are not manually counted, they are automatically calculated.
Thanks jrap. Out of curiosity, what was the problem? Was it something in how the trophy points were set up, or was it an actual bug in the software? Given how quickly you fixed it, I'm guessing it was a setup issue.This bug should be all fixed now. Better make some more room on your trophy shelf.
It was my inability to set it up properly A bug in my brain and not a bug in the software.Thanks jrap. Out of curiosity, what was the problem? Was it something in how the trophy points were set up, or was it an actual bug in the software? Given how quickly you fixed it, I'm guessing it was a setup issue.
There is still a problem. For instance, Wendy still has not received points for either the 2500 Post level or the 10,000 Post level while everyone else that I've checked that has passed those levels have received the points.This bug should be all fixed now. Better make some more room on your trophy shelf.
Thanks.It was my inability to set it up properly A bug in my brain and not a bug in the software.
Thread starter | Similar threads | Forum | Replies | Date |
P | which formulas should I use to calculate the potential in points A in both pictures? | Homework Help | 4 | |
I got me a trophy! | Off-Topic | 3 | ||
Vince Lombardi Trophy | Off-Topic | 15 | ||
Error in Trophy Point calculations | Feedback and Suggestions | 17 | ||
Trophy Points? | Off-Topic | 9 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
