Trivial DMM question...
Discussion in 'General Electronics Chat' started by EEMajor, Oct 19, 2006.
  1. EEMajor
    Aug 9, 2006
    67
    Hey everyone,
    I have a trivial, "doesn't really matter" question about DMM's. I have always had some really cheap DMM's, the most expensive one I owned was about $40.00
    I just purchased a new Fluke DMM, model 189. It has a much higher precision then any other I have owned, and I have noticed that it will have readings that "flutter" in the microvolt range when no voltage source is hooked to the leads.
    What causes this?? :confused:
    Just curious.
    Thanks!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The apparently random readings that occur with the leads open result from small charges induced on the input from stray electric fields. They are "visible" to the meter due to its high input resistance, which allows the tiny currents in the leads to develop a significant voltage across the input resistance.
    That is a bit of a problem with an input resistance of on the order of 10 X 10^6. Imagine the fun when working with input resistances in the range 10^9 to 10^15.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    As beenthere says it's very sensitive. About the difference between a Ford with no power steering and an Audi with power steering. :p
  4. EEMajor
    Aug 9, 2006
    67
    Alright, thanks for the info guys! I think I'm hooked on Fluke, good stuff.
