Trip-Switch testing circuit …
Discussion in 'General Electronics Chat' started by ranatungawk, Jul 17, 2010.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    Please Send me a simple 230V/30mA (normal home used one) Trip-Switch testing circuit …
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    Do you mean 230v/[30A] circuit breakers, as in the electrical panel at the electrical service entrance in the house?
    Ken
  3. tom66
    May 9, 2009
    2,613
    214
    Since you say 30mA are you talking about a RCD (residual current device) or GFCI (ground fault current interrupter)? 15mA to 30mA is the typical differential current for one of those devices.
    Note that asking the circuit for an actual circuit breaker is a bad question, because most do not contain circuitry. They work thermally, wire heats up if you put current through it so you can set up a thermal trip. These are effective, safe and cheap to make. A few might be electronic, but these are rare.
    If you are looking for a current limiting circuit you need to specify if you want the circuit to trip, or to reduce the voltage to compensate.
