Trimming Potentiometer max. power?
Discussion in 'General Electronics Chat' started by hazim, Mar 14, 2008.
  1. hazim
    Thread Starter Active Member
    Jan 3, 2008
    419
    13
    Hi.
    what is the maximum power a normal trimming potentiometer can go through???:confused:
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What do you call "normal"?
    They have various ratings, some as low as 0.04W.
    Best to look at the datasheet to be certain.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The entire resistive element has a max power rating of about 1/2W. If only half the element is in-circuit then its rating is only 1/4W. If only a small portion of the element is in-circuit then it might smoke and burn.
