Trimmer Pot with knob and positions?
Discussion in 'General Electronics Chat' started by Fuji, Nov 13, 2014.
  1. Fuji
    Nov 8, 2014
    100
    I have an SMD trimmer pot but I don't like it when I twist the knob it swiftly goes to the end. I want it to be on positions. Where can I find 2, 3 or 4 positioned trimmer pots? I usually find some bigger potentiometers with positions most of the time.
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    thre are none like that, there are however 5 and 10 turn pots with indicaating knobs. for an arangement like shown, I would use several pots and a switch, switch between pots.
    Fuji likes this.
  3. ISB123
    May 21, 2014
    1,240
    531
    You want pot that snaps in position?You can use Rotary switch and resistors of different value in series with every position of the switch.
    Fuji likes this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    If you want known preset positions there is also miniature PCT rotary slide switches of various number of positions that could be set up with fixed resistor values.
    (I see ISB beat me to it)!
    Max.
    Fuji likes this.
