Trimmer heating up
Discussion in 'The Projects Forum' started by paulepc, Apr 30, 2014.
  1. paulepc
    Apr 2, 2014
    55
    I have a variable .1 to .3 dc voltage into my op amp and need +/- 10 volt out so at .2 volts in I need zero out. this circuit does work, but the trimmer gets very hot.
    I am not drawing much current, so why is the trimmer getting so warm?
    Power supply +/- 12 volt 5 AMP
  2. Alec_t
    Sep 17, 2013
    5,972
    1,135
    You could have nearly 24V across the trimmer, which would drive 24mA through it. That means the trimmer would dissipate ~576mW of power; so it's not surprising it gets hot! Use a higher value trimmer, e.g. 10k, 20k or 50k.
  3. paulepc
    Apr 2, 2014
    55
    Thank you. I used a 1K to get finer control of my centre voltage I'll change it to 20K
    Paul
  4. Alec_t
    Sep 17, 2013
    5,972
    1,135
    The way you are using the trimmer to tap off the opamp output will give you the same degree of control regardless of its value. To get finer control you would normally connect a given resistance trimmer in series with a higher resistance fixed resistor; or else use a multi-turn trimmer.
    Metalmann likes this.
  5. paulepc
    Apr 2, 2014
    55
    Excellent! Thanks Alec. will modify now.
    Paul
  6. BobTPH
    Jun 5, 2013
    806
    121
    Shouldn't the trimmer be connected to ground instead of -12V? That would help. But I agree, you should use a 10K trimmer. 1K is probably too low for the op amp output.
    Bob
  7. paulepc
    Apr 2, 2014
    55
    Cant use ground as I need to get -12 Volts. Thanks.
    Paul
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    The wiper needs to swing between +0.91V and -0.91V. This means that the pot must be at least 25% of the total resistance between amp 1's max output and -12V.
    Also, you now are pulling 15.3 mA from amp 1's output worst case.
    You can get greater adjustability, reduced stress on amp1, and lower pot current all by adding 2K to 3K in series with the low side of the pot.
    ak
  9. paulepc
    Apr 2, 2014
    55
    Low side? you mean between the -12 and the pot. I have put in 15K but can't get the centre volts. so thats where you get the 25% from am I on the right track?
    Paul
  10. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    Yes, between the -12V and the pot. But lets back up a bit.
    Is the pot a calibration adjustment or an operational adjustment? That is, is it set once to map the 0.1 - 0.3V input to +10V - +10V output, or is it routinely adjusted as part of the use of the circuit?
    If the former, then I'm not sure howthis thing works. You need a DC gain of 100 and an input offset of -0.2V, but you have an amp gain of 121. So are you trying to get both gain and offset tweaks in one device?
    ak
  11. paulepc
    Apr 2, 2014
    55
    Ok Thanks.
    It is a set once and forget, I hope! I am using LM324N Quad Amp but using just 2 out of the 4 at present. I don't mind adding to the circuit to get it done properly, If you thick I need another stage I am happy to do that. I see you worked out the maths, I have not long started with electronics so finding my way, always open to advice.
    Paul
  12. Alec_t
    Sep 17, 2013
    5,972
    1,135
    You could provide the necessary gain and offset with a single opamp, like this:
  13. paulepc
    Apr 2, 2014
    55
    Thanks Alec. I'll make up a circuit and give it a go.
    Paul
  14. paulepc
    Apr 2, 2014
    55
    Alec. On the circuit you have shown. My input has chaneged to 1.4 to 3.2 volts what needs changing in the circuit.
    Paul
    Cymru!
  15. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Are you sure you have R3=1k?
  16. paulepc
    Apr 2, 2014
    55
    Sorry Alec, I have confused the issue. What I was trying to say was that originally I was out putting .2 volts mid range. I have changed the software and I am now getting 1.4 to 3.2.
    this is feeding into your circuit I have just completed, but due to the higher input I was asking what I need to change to cope with the new voltage I am generating.
    Thanks Paul
  17. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Try these values:
  18. paulepc
    Apr 2, 2014
    55
    Thanks, will try today.
