trimmer cap adjustment specifications
Discussion in 'Wireless & RF Design' started by sudev, Aug 28, 2013.
  1. sudev
    Aug 28, 2013
    I just got a trimmer capacitor to include in a tank circuit as a part of a transmitter, it's ~3-33pF. Before I begin tuning I wanted to confirm the limits of how many times I can turn it in each direction. Consulting the data sheet from Vishay, it says:
    Maximum 10 cycles: Rotation in 180° only (the
    electrical and mechanical performance is not guaranteed if rotated beyond 10 cycles)
    What constitutes a "cycle" in terms of distance or angle of rotation, and what is meant by rotation "in" 180 degrees? Any help/previous experiences would be appreciated.
    The link for the data sheet:
    http://www.vishay.com/docs/28527/bfc2808-75mm.pdf
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    This is only a guess, but the word "cycle" properly refers to a complete cycle (back to the start).
    If max rotation is 180' then a "cycle" would likely be left->right->left again (total 360' moved).
    So if there is a wear issue it occurs after 3600 degrees of movement.
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
