triggering system using shift registers
Discussion in 'The Projects Forum' started by Whaldo, Jun 7, 2011.
  1. Whaldo
    Jun 7, 2011
    I'm pretty new to circuitry, but it would be great if someone could help me out a bit with this.
    My project is to trigger several cameras at the same time.
    For this I would like to use the Nano Arduino, shift registers and opto-isolators.
    I'v drawn up what I think might be the correct layout for everything below, although I'm not sure if it's correct.
    Components
    Circuit schema with test LEDs
    Any help with this would be greatly appreciated :)
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    The circuit will not work, as the 1uF capacitor on the pins 12 of the 595's will block the pulses.
    Bertus
    Whaldo likes this.
  3. Whaldo
    Jun 7, 2011
    Thank you Bertus,
    If there's anything here that doesnt look right, let me know.
    Thanks again :)
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not quite block the pulses, but pass them off to ground and attenuate them below logic levels.
    Whaldo likes this.
