Post the detailed specs on your anemometer.
Supply voltage?
Load current from relay?
Your experience level?
probably 17 meters per second wind speed.
I don't have that information but I'll post it tomorrow. Can you tell me the general idea of how this is going to work?Details make it a BIT clearer.
What kind of output or signal is available from the anemometer?
Max.
But in order to supply some meaningful ideas, details of the equipment you intend using needs to be supplied.Basically the theory and the calculations if any that I would have to do?
Ok let me quote the idea for the anemometer my team came up withBut in order to supply some meaningful ideas, details of the equipment you intend using needs to be supplied.
Or if you have a concept and want to design the equipment for it, more detail and info as to what you want to achieve is needed.
But I would think the more practical approach is to obtain an anemometer and design around it.
Max.
by Jake Hertz
by Jake Hertz
by Jeff Child
by Aaron Carman
