You will probably need to aperture the photo-diode. That is to say you will need to place a short length of hollow tube directly in front of the photodiode. This helps eliminate the interference from the ambient light. You probably have your setup in a room with fluorescent lighting. That is probably the source of the 60Hz or 120Hz noise. Turn off the lights and see if the noise goes away.
hgmjr
hgmjr
