Cool thanks, also I'm stuck on this question too. "Show how a negative edge triggered D Flip-Flop can be formed using S-R Flip-Flop?"It depends on your application but in logic applications its enabled.
Depends on who is choosing the terms because there is no rigid, universally accepted terminology.I've got this question-what is the the triggering input of a Flip-Flop is called?
Would it be "enable"
There are a few ways to do this depending on if you want the output to appear immediately after the negative-going edge or if you want the output to appear on the following rising edge.Cool thanks, also I'm stuck on this question too. "Show how a negative edge triggered D Flip-Flop can be formed using S-R Flip-Flop?"
Any idea?
Appreciate the help
