Hi I'm building a basic 4-step sequencer that needs to generate a CV and Gate signal. The Gate should be a 50ms pulse at +5V and the CV should be between 0 and 5V. I've come up with the following circuit using various resources online, however, when building it I actually ran into a problem, the pulse shaper fails because the 4017 doesn't go low long enough to retrigger the one-shot.
The circuit works like this: a 555 (IC1) clocks a 4017 divider (IC2) which divides the frequency. The 0 output of that divider is fed as the clock to another 4017 (IC5) which sequences the four channels. The channel outputs go through 4 switches and each switch is bussed into a 555 one-shot (IC3) to shape the pulse into a 50ms burst. But as I said the last part isn't working. Does anyone have any tips on how to make these short bursts from a 4017 in a better way? I thought this would work since its possible to clock a 4017 from another 4017 but it seems the 555 trigger is not picking up the low gap in between sequencer steps and just reads the gate as always high...
