I'm trying to build a highvoltage distrubutor to my dragrace snowmobile. What I figure about now is how I should pick up the trigger signal from my hall sensor. It's a two wire sensor type. Could someone point me to the right direction
The thing is it's no specification on the sensor available. But I will test it with a logger to see what it sends out.
I was thinking of a comparator with a voltage or current threshold. I have read the specifications on a lot of comparators, what I don't understand is how to set a specific threshold on the comparators ? I am not that used to build own circuits so to speak
Are you converting a sled to electronic ignition, changing an existing ignition system, or "other"?
What model engine/sled is it, or do you have This?
Comparators swing their output to the polarity of the greater input. If powered by 5V and ground, when the + input is higher than the - input, the output will be high/5V, when the - terminal is a higher voltage than the + terminal, the output will be low/0V
To compare against a voltage, usually a voltage divider is set up for the level on one input, and the signal is on the other input. Which input is used for the signal depends on if a high or low value is desired when the threshold is met.
thatoneguy: Ok I can see what you are saying about comparators, so I have tried a circuit in pspice but it won't do what I think it should do what have I done wrong ? http://www.pixbox.se/pic_show_id26516799.html
Ah it was a pushpull comparator my new circuit seems to work, can someone please tell me if it looks ok The simulations seems ok, but could be something else I have missed
At quick glance, your circuit has voltage dividers on both inputs, with the additional squarewave source. Try simplifying it using two 10k pots, both with one end to power, and the other end to ground. One wiper to each input. Then simulate one moving with the other centered, and vice versa. I haven't used OrCad/LTSpice, so am not sure if that's a simpler simulation. With the existing circuit, add two additional probes on the two inputs to see what the input voltages are, if one never "passes" the other, the output will remain the same.
Below is a link to a good article from Maxim, which also covers a topic (hysteresis) you may need in the ignition circuit as well. In addition, it shows schematics for the input to be both on the inverting and non inverting inputs, with diagrams of the input/output of each. It should expand your understanding, as well as the related links at the bottom of this file. They are all from Maxim and "safe":
