Tricky physics question
Discussion in 'Physics' started by redacejr, May 30, 2008.
  1. redacejr
    Thread Starter Active Member
    Apr 22, 2008
    85
    If a 3400rpm 3v motor is going at full speed with its terminals slowly heating up due to friction, at what MACH is an unbalanced weight at the end travelling??
    THERE IS AN ANSWER
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Need the diameter of the shaft or the radial distance of the weight from the center of rotation. Are you suggesting that it might be going supersonic?
  3. Caveman
    Apr 15, 2008
    471
    Sounds like a trick question. Technically, you need the fluid that the motor is travelling through as well to determine it's mach number.
  4. triggernum5
    May 4, 2008
    216
    So 3V saturates the field at 3400rpm.. Thats info about the electrical properties of the coil, which can give you the current, which can give you the power, which can be calculated against the angular velocity to give you the moment of inertia.. But I get stuck there since different shapes of different lengths can yield the same moment of inertia.. Or are we to assume the typical bar's mr^2?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The terminals "slowly heating due to friction" sounds like the shaft might be stationary while the motor revolves around it. It's a clue of some sort, though.
    How does one define "unbalanced weight at the end", though? End of what?
  6. triggernum5
    May 4, 2008
    216
    I overlooked the point that they were heating from friction, assumed resistance.. Would magnetostriction count as friction? If the question implies mechanical friction than I can't see how any bounds/parameters can be derived since its unquantified, and heat is generated by any motion out of vacuum..
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    3400*60*pi*D/Vs where Vs is the speed of sound in length per second in the surrounding media, and D is the D is the diameter in same units length of the path traveled by the weight.
  8. triggernum5
    May 4, 2008
    216
    In that context its more of a homework question than electronics forum puzzle..
  9. redacejr
    Apr 22, 2008
    85
    HINT :
    the speed is below MACH1
    the shaft diamiter is not needed
    it is very tricky
    the motor is HORIZONTAL!!!!
  10. redacejr
    Apr 22, 2008
    85
    unbalanced as a p[iece of weight that is attached to the shaft NOT AT ITS C.O.G
  11. recca02
    Apr 2, 2007
    1,211
    Not that I claim that I'll be able to solve this one, but
    Is it not required to know the type of motor? AC/DC?
    What does it mean by "terminals" here? The supply terminals?(brushes?)
    Perhaps a small rough schematic will also help.
  12. triggernum5
    May 4, 2008
    216
    I'll be the first to admit that your hints were not sufficient (as of yet atleast)..
    The only way I can see the horizontal fact being relevant is if gravity also involved in the calculation as a component of SHM equations..
  13. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Okay. I get it now. Zero is the answer.
  14. redacejr
    Apr 22, 2008
    85
    OMG the closest guy was very far away from the answer.
    immagine a horizontal 3v dc motor with an unbalaced weight.... this would make the motor do extra effort. THERE IS NO SPECIFIC MACH!!!!! the motor is slowing down until 0 rpm.... now youre saying... damn that was so easy... the numbers are all useless:mad::mad::mad:
  15. redacejr
    Apr 22, 2008
    85
    and at the moment the motor is switched on the weight is at 0.34 mach
  16. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The above makes no sense.
  17. triggernum5
    May 4, 2008
    216
    Alot of it doesn't make sense.. What if the armature was a mile long, at 3400rpm, that would be waaay more than mach 1..
    Your question asked us to give an answer in terms of velocity relative to sound, and you stressed that there was infact an answer.. As far as I'm concerned, there is no answer according to your more recent explanation.. Besides, explain to me how anything with greater than 0 length (required for an unbalanced load) could be stationary (Mach 0) at '3400rpm'..
    What a bummer, I was expecting something cool..
  18. redacejr
    Apr 22, 2008
    85
    look, its not i who wrote this question and the guy who gave me the answer is a friend. i just thought it was an interesting question to post and it ended up in armagaddeon =.=
    the answer should be :
    the motor is not travveling at one specific speed (mach) but rather constantly changing its speed due to frictional heat. (well thats wt my firend said)
    there is no other explenation for it... i wrote all the details and if someone figures it out in another way please tell me XD
    and also i agree that the horizontal motor detail should be a clue but i cant figure it out :confused::confused:
  19. redacejr
    Apr 22, 2008
    85
    and the guy posting above... whe i said there is an answer i meant theat there should be one as every question has an answer .... got it and IM NOT SAYING IT IS TRAVELLING AT 0 MACH!!!!.... ITS JUST SLOWING DOWN
