Tricky Algebra question
Discussion in 'Math' started by Jess_88, Jun 3, 2011.
  1. Jess_88
    Apr 29, 2011
    174
    Hey guys.
    I was wondering if someone could show me the working out (simplification) for these two equation. This isn't a homework question... just study. If more information is needed... let me know :)
    1)
    2)
    thanks guys :)
  2. jegues
    Sep 13, 2010
    735
    43
    For 1,
    \frac{5}{s+2} = \left( \frac{s+1}{2s+1} \right)V_{o}
    \frac{ 5 \times (2s+1)}{(s+2)(s+1)} = V_{o}
    \Rightarrow \frac{10s+5}{(s+2)(s+1)} = V_{o}
    Or if you're confused by the first simplification,
    \frac{V_{o}}{2s+1} + \frac{V_{o}}{2 + \frac{1}{s}}
    = \left( \frac{1}{2s+1} + \frac{1}{\frac{2s+1}{s}} \right)V_{o}
    = \left( \frac{1}{2s+1} + \frac{s}{2s+1} \right)V_{o}
    If I have time later I will look through the 2nd one as well. (It's the same type of algebra, nothing difficult)
    Jess_88 likes this.
  3. Jess_88
    Apr 29, 2011
    174
    ah thats great!
    Yeah I understand its simple... I just haven't worked with such fractions in a long time.
    If you do have time to do the second one later that would be great.
    Thanks for the help :)
  4. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    You need to take it in steps. First step is to eliminate the 2/S denominator by multiplying both the top and bottom of the second term with S/2
    Such that we have:
    \frac{3}{S} -Vo\ \  -\frac{1}{2}-\frac{SVo}{2}\ \  +\frac{4}{S}-Vo\ \ =\ \ 0
    Collecting the terms with Vo on one side we get
     2Vo+\frac{S}{2}Vo\ \ =\ \ \frac{7}{S} - \frac{1}{2}
    Multiplying both sides by 2 and simplifying:
    \Rightarrow\ \ \ \ Vo(4+S)\ \ =\ \ \frac{14-S}{S}
    \Rightarrow\ \ \ \ Vo\ \ =\ \ \frac{14-S}{S(S+4)}
    Jess_88 likes this.
  5. Jess_88
    Apr 29, 2011
    174
    aaah! I got it!
  6. victorhugo289
    Member
    Aug 24, 2010
    49
    I thought you had to solve for something in here, but this is a plug-in-the-values type of equation.
    Not much simplification, really.
    It's more like a formula. It is a formula...
  7. Jess_88
    Apr 29, 2011
    174
    Its a Laplace transformation question. I need to arrange the equation in terms of Vo and use partial fraction to determine the Laplace transformation.
  8. KL7AJ
    Nov 4, 2008
    2,047
    295
    You "just" need to find the common abominator. :)
    Eric
