tricky algebra problem
Discussion in 'Math' started by chesart1, Nov 24, 2007.
  1. chesart1
    Thread Starter Senior Member
    Jan 23, 2006
    269
    Perhaps this is a good way to teach a student to think before diving into a solution to a problem....
    what is the product of the binomials
    (x-a)(x-b)(x-c)(x-d)(x-e)(x-f)(x-g)(x-h)(x-i)(x-j)(x-k)......(x-y)(x-z)
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Assuming this sequence in alpha-sequential and there is an (x-x) in there, then the product of the binomials is 0.
    Dave
  3. recca02
    Apr 2, 2007
    1,211
    i must admit i got foxed by this one, since Mr chesart1 wisely made the (x-x) inconspicuous.:(:D
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Yes very sneaky! :D
    Here is a question: Removing the (x-x) binomial, how many sum of products are there when the brackets are multiplied out?
    Dave
  5. recca02
    Apr 2, 2007
    1,211
    26.:cool:
    the answer is quite simple isnt it?..but i wont give away any hint now(will edit later perhaps:rolleyes:)
    i'll be pretty embarrassed if at all i missed the correct answer:D.
    one reason i got tricked was i assumed all of the terms as constants and the 'x' as variable (and was under the impression any other alphabet not shown represent a constant without thinking about the hidden x)
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Is it 26? The order of the sum of products term will be 26, but will it have 26 product terms. Consider:
    (x-a)(x-b) = x^2 - ax -bx +ab = x^2 -(a+b)x +ab
    Two binomials gives 3 sum of product terms.
    (x-a)(x-b)(x-c) = x^3 -ax^2 - bx^2 -cx^2 +abx +acx + bcx - abc = x^3 - (a+b+c)x^2 +(ab+ac+bc)x - abc
    Three binomials gives 4 sum of product terms.
    So I go for 27 - nearly the same!
    Whether x is constant, variable, real, complex or other x-x = 0.
    Its all fun isn't it! :D
    Dave
  7. recca02
    Apr 2, 2007
    1,211
    yes but i thought one x will be variable and the other constant thats where i went wrong.
    for a quadratic we have three terms,
    therefore for polynomial of order 25(26-1,since x-x is absent) we should have 26 terms right?....did i go wrong somewhere?
    sure is!:D
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ok, I see. Anyone using the same characters for two different variables needs detention!
    D'oh! How dumb am I - and I set the question! :(:p
    Yes 26 is the answer.
    Dave
