Trick question
Discussion in 'Off-Topic' started by musicalavtech, Jan 18, 2014.
  1. musicalavtech
    Mar 23, 2012
    32
    How long have wireless, digital communications been around?:D
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    Do you mean smoke signals, light and flags?
  3. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Well for wireless since around the late 1800s using spark gap transmitters.
  4. spinnaker
    Oct 29, 2009
    5,076
    1,177
    And you could consider morse code as a form of digital communication.
  5. musicalavtech
    Mar 23, 2012
    32
    Well for techy types, that was too easy.
  6. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Don't forget the abacus.
  7. #12
    Nov 30, 2010
    16,703
    7,338
    Do you mean the abacus with bamboo rods instead of wires, or master and slave abaci that match each other over a distance?
  8. spinnaker
    Oct 29, 2009
    5,076
    1,177
    If you want to go that route then the drum could be considered digital communications too and predate the abacus by a large margin.
  9. #12
    Nov 30, 2010
    16,703
    7,338
    I can see the drum as wireless digital communication, but I'm having difficulty with the abacus communicating over a distance.
  10. JoeJester
    Apr 26, 2005
    3,401
    1,218
    No distance was specified. Only digital communications.
    I like the drum answer.
  11. monster_catfish
    Mar 17, 2011
    110
    107
    Pursuing the drum concept further, I wonder if creating diffuse smoke signals on a windy day, while drumming out a pre-agreed code in an open area devoid of distracting echoes, could be regarded as the first instance of combined digital and analog data transmission.
  12. tracecom
    Apr 16, 2010
    3,879
    1,396
    First digital communication: caveman uses index finger to point. :D
    killivolt, KJ6EAD and GopherT like this.
  13. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Most of the cavemen I know use their middle finger to point. :)
    PackratKing likes this.
  14. tracecom
    Apr 16, 2010
    3,879
    1,396
    I'm glad you said that.
  15. WBahn
    Mar 31, 2012
    18,087
    4,917
    Ah, but long before the drum, you can bet that someone communicated something to someone else by clapping their hands.
  16. GopherT
    Nov 23, 2012
    6,311
    4,031
    First transmission of an electric signal - Stephen Gray (1720 - 1736 timeframe). Static electricity - made with a glass rod and silk cloth.
    Not wireless but essentially digital. It was mostly a novelty. A Frenchman then had the idea to use 26 parallel wires to achieve communication. Not efficient and obviously pre-ASCII.
    Not wireless but electric. I really liked the drum beat answer!
  17. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Tracecom stole this idea out of my head and presented it as his own. ;)
  18. tracecom
    Apr 16, 2010
    3,879
    1,396
    Yes, and I was amazed at what else I saw in there. :eek:
    KJ6EAD likes this.
  19. WBahn
    Mar 31, 2012
    18,087
    4,917
    So which finger did YOU use to communicate your response to him? :D
    KJ6EAD likes this.
  20. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Are you certain you did not mean frightened? ;)
    KJ6EAD likes this.
