Triangular Resistor Network
Discussion in 'Homework Help' started by jegues, Sep 15, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached for problem statement.
    I keep confusing myself trying to reduce this resistor network into one single resistor.
    Is there an efficient method for dealing with resistor networks in this configuration?
    The resistors are sorta in a DELTA configuration so this is probably the key to solving the equivalent resistance of this network, however I'm not still not seeing it.
    Does anyone have any ideas, or any suggestions then can make to me so I can make a decent attempt at it?
    Thanks again!
      File size:
      18.6 KB
      126
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. jegues
    Sep 13, 2010
    735
    43
  4. victorhugo289
    Member
    Aug 24, 2010
    49
    Using Delta to Wye conversion is tedius, I prefer to use simple series-parallel redrawal and then apply Node Voltage Method, here, you can see the process of redrawal, first redrawal, second redrawal. You will see that there is a little Bridge circuit in there, yeah, beautiful circuit, ain't it.
    The first is normal redrawal,
    The second is the Node Voltage method applied
    I used a 7 volt battery to find out the current and....resistance of course!
    RESISTANCE IS: 90 ohms, (just as Jony said)
  5. jegues
    Sep 13, 2010
    735
    43
    This is what I tried first but I'm not confident enough in my abilities to redraw it correctly.
    Is there any method to your madness? Aside from experience and intution of course!
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    This is another novel solution using circuit symmetry.
    Khan111 likes this.
  7. victorhugo289
    Member
    Aug 24, 2010
    49
    Yes, there's method, Jegues, gee, I wanna go step by step, ok:
    You see the two top resistors in the first redrawal? one is 81 ohms and the other is twice as much, i.e. 162 ohm. So, the 7volt battery feeds 86.4mA to the 81 ohm, then it feeds half as much to the 162 (7 divided by 81...and so on)
    Now you have the two currents that you see in the current source redrawal.
    If you're wondering why there's 9 resistors in the original circuit and only 7 in the current source circuit, is because the last 3 resistors to the right can be made into one.
    Now, what you see in the current source redrawal are somehow 7 resistors all 81 ohms.
    And there is a little bridge circuit in there! you solve that little bridge circuit separately, using a battery to get the current, to get the one resistance.
    Then you end up with 3 resistors in parallel, 2 current sources in parallel which can be added into one. The you solve it and you will get the voltage for the bottom resistor next to the 7 volt battery of the original circuit, which happens to be 3.5V.
    Now you got it.!
  8. victorhugo289
    Member
    Aug 24, 2010
    49
    Don't let my 'explanation' confuse you even dasdasdmore!
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
