Without wanting to complicate things, you may also come across the letter d used in these terms, as in dV = 0, and its meaning is as thingmaker3 describes above.
Depending on who you speak to, d should be used with respect to another variable, for example dV/dt = 0, means change in voltage in a particular (with respect to) time. Just be aware of the subtleties.
