Triangle Wave Circuit
Discussion in 'General Electronics Chat' started by JasonL, Feb 13, 2016.
  1. JasonL
    Thread Starter Active Member
    Jul 1, 2011
    47
    Hi All,
    I need help understanding how to analyze this schematic that is attached or at least where to begin. I want to create a voltage controlled PWM circuit. I learned this can be done by inputing a dc voltage and a triangle wave into a comparator. The duty cycle is changed by varying the dc voltage.
    I need help understanding the triangle wave generator. I understand how an integrator and a comparator works by themselves. I know integrating a square wave will give a triangle wave.
    The feedback and no external input is making this circuit difficult for me to understand. Where and what are the initial conditions? When I look at the circuit on Spice, it looks like having the voltage at vref = 0.5vpp of the triangle wave is critical for the circuit to work. But I don't know how vref becomes 2.5V. I can simulate this on Spice fine and see it working, but I want a deeper understanding of this circuit and learn how to analyze it.
    Any help is welcome! Thanks!
  2. Veracohr
    Jan 3, 2011
    559
    77
    Vref won't become .5Vpp, you have to enforce that to get it to oscillate. Create a voltage divider from the 5V source and connect Vref to the midpoint.
    R3 provides positive feedback for U1, forcing whatever the present conditions are (including initial conditions) to change and tend toward oscillation.
  3. JasonL
    Jul 1, 2011
    47
    If your response is true, then it would make it easier to understand how to analyze the circuit, but I'm not quite convinced that's the case because the Spice simulation shows the circuit works without having to set vref to 0.5vpp with a voltage divider.
    I attached the simulation.
  4. GopherT
    Nov 23, 2012
    6,303
    4,019
    Here is an explanation from a very old book. It looks at the integrator then the comparator with hysteresis. Check page numbers, pictures are out of order.
    JasonL likes this.
  5. JasonL
    Jul 1, 2011
    47
    Thanks Gopher! This is helpful. May I ask what book is this? I'm interested in knowing how the equations are derived, especially 6-10a and 6-10b.
  6. GopherT
    Nov 23, 2012
    6,303
    4,019
    This was From the second edition (1982) but I think they published seven or eight editions of it (1998?). Not sure if all of them have the same content over the years.
    http://www.ebay.com/itm/Operational...1934775859?hash=item33ac57ee33:i:221934775859
    http://www.ebay.com/itm/Operational...2072767833?hash=item2810561159:i:172072767833
    JasonL likes this.
  7. Veracohr
    Jan 3, 2011
    559
    77
    You used the Universal Opamp model right? Replace that with a real opamp model and you may find the simulation results are different.
    JasonL likes this.
  8. JasonL
    Jul 1, 2011
    47
    You're right Veracohr. Thanks for catching this!
  9. crutschow
    Mar 14, 2008
    13,475
    3,362
    That may work in the simulator, perhaps due to it being an ideal op amp model, but in real life you will need a source to establish Vref.
    Try the simulation with a real op amp model and you'll likely see the problem.
    Post your .asc file.
