TRIAC Help
Discussion in 'General Electronics Chat' started by shadowrider, Mar 6, 2012.
  1. shadowrider
    Mar 6, 2012
    Okay. I am trying to control 28vac using 3vdc Best I have come up with is a triac. Anyway to make the triac closed by default and triggered open with the 3vdc? Basically I am trying to make the triac to fail closed allow the 28vac current to flow that way if the micro-controller sending the signal to the triac fails the 28vac will continue to flow. Then will the micro-controller sends a signal it will open the triac interrupting the 28vdc.
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    You should use an AC opto-coupler to drive the gate of the triac.
    Or use an AC solid-state relay.
  3. praondevou
    Jul 9, 2011
    2,936
    489
  4. shadowrider
    Mar 6, 2012
    Thanks for the replies. The 28vac current is about 200 ma. Its driving a motor that I am trying to turn off using a triac. I have run the 28 vac to MT1 and MT2 of the triac. I have 3vdc signal coming from a micro controller to trigger that gate on the triac. I am just trying to make the motor always on, unless a signal comes from the microcontroller to open the gate of the triac cutting current to the motor. So is a normaly closed solid state relay the way to go? I am searching on digi key and looking, but the question is how do I tell if its normally closed or normally open? Thanks for your help.
  5. shadowrider
    Mar 6, 2012
  6. MrChips
    Oct 2, 2009
    12,633
    3,453
