Triac dimmer noise help
Discussion in 'The Projects Forum' started by winestill, Jan 25, 2012.
  1. winestill
    Nov 1, 2011
    7
    I made dimmer circuit, used as heating element control, like this one. Also I used
    around 35uH choke 16A. When I turned on the circuit this buzzing noise
    came from the circuit and the element. So I turned it off, took the choke
    off and the noise came only from the element but small noise came from
    the circuit. I used radio to listen to statics which came from the control and
    it seems that without the choke the static decreased.
    Can anyone tell me what I can do? Regulation in my country says I have
    to eliminate both RFI and EMI.
  2. winestill
    Nov 1, 2011
    7
    ttt ttt ttt
  3. CDRIVE
    Jul 1, 2008
    2,223
    99
    Are these typos? C1=150uF x 2 C5-=150uF x 2. Are you sure that's not nF?
    Chris
    Edit: Don't bump your threads. It will anger the Mods.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    For the coil, put a few drops of thick superglue over the windings and spray with accelerator after a while, or use a hot glue gun to keep the windings from moving.
    With the inductor removed, you say "The device" is still making noise. Are you referring to electrical noise, or audible noise?
    Do you have an oscilloscope?
    What is the purpose of the capacitor and resistor bypassing the Triac?
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
    I was guessing it was a snubber of sorts ...but those cap values?!
  6. winestill
    Nov 1, 2011
    7
    Oops didn't know about the bumping.
    Yes thats typo. It should've been 150nf.
    thatoneguy, this noise im talking about is electric one, buzz noise.
    And the resistor and cap in series is snubber
    No I don't have oscilloscope.
    It seems I can't get my self clear enough, somehow. :(
    When I have all my components on the board a buzz noise is coming from it and the heating element. I took away the L1 and the noise did damp a little bit. So I took away C1 and it's still buzzing. Then again I took the C4 away and yet again the buzzing was coming. So I disconnected C3 and the buzz was STILL on and also when i take C2 but I connected C3 to the board.
    I've bought new caps and it's still coming. But here's the thing. Last day I tried polyester cap, like this one, and the buzzing did decreased dramaticly. Why is that happening? I had WIMA MKS4 caps and some other similar.
  7. CDRIVE
    Jul 1, 2008
    2,223
    99
    That's not electrical noise it's mechanical vibration. It's being generated from the high current/fast rise time when the Triac fires.
    Chris
  8. winestill
    Nov 1, 2011
    7
    :eek: vibration.
    So I was wrong all the time, spending hours finding out what it is :mad:
    DAMN!
    So what do you suggest? Glue it to damp it?
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you are on a solderless breadboard, the connections can physically move.
    If on a PC board, look toward a solid mounting for the inductor and Triac, try touching each component with an insulated (plastic) screwdriver, and listening to the screwdriver stick itself, like a stethoscope, to narrow down the noise source.
