I had thought to use a Triac because ...
1. The price is significantly cheaper than a relay (This is my number one consideration I am quite poor).
2. Current levels needed to trigger the relay were higher (Though if I end up using an opto coupler this might not be an issue)
3. Triac doesn't seem to be as bulky.
"at those level of current and voltage"
Is there something about 24 VAC and .35 Amps that would make a relay a good alternative where some other current and voltage level it wouldn't be?
Once again thanks for all your help,
Z
Z
