Triac calculation
Discussion in 'Math' started by Forsa, Aug 18, 2009.
  1. Forsa
    Aug 18, 2009
    this question is very easy but im out of idea how to find the answer.. pls help..
    supply volt : 230V
    load resistance : 20 ohm
    load power : 2404.7W
    rms load voltage : 219.3V
    current 10.97A
    wat is the average power loss in the triac, where it has threshold voltage Vo = 1.1V and slope resistance 5.1mili ohm..
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Since this looks like homework you should post it in homework help - more members would tend to look there rather than here in the math area. Also if it is such an easy question you should attempt and post a solution - otherwise people are reluctant to help .....
