triac and optocoupler for low water pump switch
Discussion in 'The Projects Forum' started by dedioni, Sep 16, 2011.
  1. dedioni
    Sep 16, 2011
    Hi I need help on this schematic, the aim is to control a water pump (max 35W of load) which has to be shut off when the water level goes low.
    I searched for some floating switches but they are DC and low voltage (being in contact with water that makes sense).
    I've come up with the schematic I attach, I have a triac which is piloted by a gate which controls the 230Vac terminals A1 and A2, on the other side I have a low voltage DC line (9v most likely) separated by a photo-coupler so that 230Vac don't get in contact with water.
    I need help on the choice of the R1 resistance so as not to burn the gate of the triac and the suggested models for the photo-coupler and triac.
    If you could tell me how to come up with the right resistance values I would be grateful.
    Thank you
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You could take a look at the MOC302X as an optocoupler.
    Those are specialy designed to drive triacs.
    If you want to power the led in the optocoupler with a 9 Volts powersource, make Rin 390 Ohms and use the switch instread of the gate in the schematic.
    I also have a link to the complete PDF on the MOC's:
    moc3010-m.pdf
    Bertus
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    Use the dc float switch to trigger a relay coil.. Relay contacts switch the AC
