Tri-state buffer
Discussion in 'General Electronics Chat' started by robby991, May 27, 2008.
  1. robby991
    Thread Starter Active Member
    Dec 17, 2007
    79
    Hello. I am trying to implement a tri-state buffer on a bread board. Is there a 74 series IC that is a tristate buffer? How can I do this? Thank you very much.
  2. Caveman
    Apr 15, 2008
    471
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Also 74x365, 74x366, 74x367, & 74x368
    BTW Caveman, that's a pretty good list
  4. Caveman
    Apr 15, 2008
    471
    Yeah, just googled it and wikipedia popped up. Never seen it before, but I'll use it from now on.
  5. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  6. robby991
    Dec 17, 2007
    79
    Thanks for the info. Quick question though. What is the difference between these tri state buffers and the transmission gates that use n and pmos transistors to pass data through? I am talking specifically about the CD4016BE analog switches. Are they equivalent?
  7. Caveman
    Apr 15, 2008
    471
    These tri-state buffers drive logic levels (low or high only) through when they drive. The CD4016 is an anlalog switch. It passes analog straight through.
