How many pn junction a tri colour LED has? I think its three, am i right ?
F Thread Starter Faisal 2121 Joined Oct 15, 2008 6 Nov 4, 2008 #1 How many pn junction a tri colour LED has? I think its three, am i right ?
thingmaker3 Joined May 16, 2005 5,083 Nov 4, 2008 #2 You are correct. Typically a tri-color LED houses three LEDs under one lens, and ties the cathodes together on a common lead.
Wendy Joined Mar 24, 2008 23,421 Nov 5, 2008 #3 I always thought tri color as in Red and Green, which could produce Yellow (tricolor = 3 colors). You're discribing a RGB diode. TriColor as I'm thinking of it is two leads, two LEDs, reverse the polaritry with AC to get yellow.
bertus Joined Apr 5, 2008 22,276 Nov 5, 2008 #4 Hello, There are also leds with red and blue in one, the third color look purple/pink (depending how bright blue is) like. Greetings, Bertus
SgtWookie Joined Jul 17, 2007 22,230 Nov 5, 2008 #5 RGB LEDs are available in common cathode and common anode configurations. They both have three PN junctions. There are also red/green LEDs that have but two PN junctions. A yellowish-brown color can be displayed by lighting up both the red and green. There are also many other color combinations available nowadays.
T trrobbie Joined Dec 11, 2008 4 Dec 23, 2008 #6 The newest ones that rad shaft has are red, green and blue in one unit. Just got one a few weeks ago.(its a cc unit) Interesting thing to play with. I`ll find a use for it someday!? Robbie in wyoming
Audioguru Joined Dec 20, 2007 11,248 Dec 23, 2008 #7 My solar garden lights have an RGB LED with 2 wires and 3 LEDs inside that slowly fade the colours.
