I disagree, most people here try to give their idea of voltage which they through experience have found to explain it better. Most of the times, when someone asks for a clear definition of voltage, they want to know of something they can relate to in everyday life(well, everyday life of an electronic geek).To the Ineffable all,
While reading some of the questions and answers in this forum, I deduce that there seems to be a bit of confusion about just what voltage is.
However, that is one great definition/explanation of voltage IMHO. Most of the times its good to start back from basics than to develop on analogies to get a better understanding of a concept.Electrical charges come in two flavors, positive and negative. Two or more like charges do not like to get together. They repel one another. To gather them together, energy has to be applied to the charges. So now the charges have this accumulated potential energy (P.E.)that was applied to the system to force the charges together. Now we can build up the same potential energy by bringing many charges somewhat close together, or we can bring few charges very close together. In both cases, we can have the same P.E. involved, but different voltages. Why is that? Well, the reason is that voltage is the energy density of the charge. In other words, it is the P.E. associated with the charges, divided by the number of charges involved. In MKS units, that is joules/coulomb. So voltage is not P.E., but it is proportional the P.E. associated with the charge. Twice the P.E., twice the voltage. When charge flows, thereby causing current to exist through a resistance, it dissipates its P.E. in the form of heat, and the voltage (energy density per charge) drops.
I recall learning something similar in 9th standard (perhaps known commonly as 9th grade out there.) I never had trouble understanding those, as a matter of fact I am more comfortable with this definition. As a matter of fact I never came across the water analogy.(actually I have more trouble relating head,pressure,velocity head etc.).
So I'll add your contribution is very much appriciated , thanks.
Edit: I was wondering if voltage is not a vector then how come the sum of voltage in three phase circuits equal zero?
how come a voltage leads or lags the other by 120 degree?
