Treadmill T-1700 blowing fuses
Discussion in 'General Electronics Chat' started by Mah-Ros, Dec 28, 2013.
Thread Status:
Not open for further replies.
  1. Mah-Ros
    Nov 27, 2013
    6
    My treadmill T-1700 control board, blowing fuse when connected to power, so i checked all parts without rectifier and Mosfet regarding erased model number by seller !!! so i couldn't guess which part used ? so it works by DC Motor 180 VDC and 205 Hp, i would appreciate if you could inform me parts or schematic diagram of Motor Driver too.
  2. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    That must a group T.M. if it is 205HP! ;)
    Can you post a pic of the board?
    Max.
    Mah-Ros likes this.
  3. Mah-Ros
    Nov 27, 2013
    6
    Sorry, my mistake ... 2.5HP
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    You just hijacked an existing thread:
    Treadmill blowing fuse.
    This is not allowed over here.
    Now you have a thread of your own.
    Bertus
  5. Mah-Ros
    Nov 27, 2013
    6
    to Bertus;
    it seems you look stupid to reply as wrong ...
    what is your mean for Hijack !!! it is regarding treadmill Blowing Fuse, so try to share problem to get response...
    it will be enough that you are not stable human in your live ....
  6. djsfantasi
    Apr 11, 2010
    2,899
    870
    Perhaps you need to research forum etiquette. Hijacking is considered bad behavior and the moderator was trying to help you. Your response however was offensive and possibly in violation of the terms of service for this site.
    http://www.allaboutcircuits.com/l_tos.html
    Please be careful with your posts.
  7. MrChips
    Oct 2, 2009
    12,622
    3,451
    AAC is a civil member-supported community that takes pride in our moderators.
    Comments such as that in your post will not be tolerated.
  8. Mah-Ros
    Nov 27, 2013
    6
    Please check bertus :confused: quote ... for any reason ...
  9. Mah-Ros
    Nov 27, 2013
    6
    Notice, So he can inform to do right ... perhaps he has big problem to attention something... so should be forward as bad words .... :eek:
  10. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
Thread Status:
