treadmill speed control help
Discussion in 'The Projects Forum' started by majorkuso, Oct 23, 2015.
  1. majorkuso
    Thread Starter Active Member
    Aug 21, 2009
    44
    We have a treadmill, but the motor control and psu unit died(one unit).What I am trying to do is control the speed of the motor with preferably a 555 timer. the motor is a DC 2hp 90v rated at 20 amps. i have a few power mosfets one rated at 100v at 100 amps. We have a fwb rectifier that drops the unregulated voltage down to about 90. i think I am overthinking the driving of the motor. i thought about putting a zener regulator to supply the power to the timer circuit but am not sure about driving the mosfet and motor.
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    Are you thinking of using a 555 in pwm mode to drive the mosfet, running the motor direct from the mains via a bridge rectifier?
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
  4. majorkuso
    Aug 21, 2009
    44
    in short yes, but running the motor from mains through the bridge could cause problems I think.
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    It is done all the time with T.M.'s and KB DC motor controllers.
    Max.
  6. majorkuso
    Aug 21, 2009
    44
    the speed controller that was bought to run it could handle the rated current. i am trying to create a custom solution.
  7. majorkuso
    Aug 21, 2009
    44
    wouldn't a steadier supply other than a fwb give better control
  8. majorkuso
    Aug 21, 2009
    44
    the fwb drops the voltage anyway so that is not the problem.
  9. majorkuso
    Aug 21, 2009
    44
    I may have a 200 v powerfet will look when I get home.
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Sorry, what is fwb?o_O
    Max.
  11. majorkuso
    Aug 21, 2009
    44
    Fill wave bridge sorry for not clarifying earlier
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Surely the voltage drop of a bridge is rather trivial at 120v.
    Max.
