treadmill project
Discussion in 'General Electronics Chat' started by h.d, Nov 11, 2007.
  1. h.d
    Thread Starter Active Member
    Oct 22, 2007
    150
    hi,
    i work iin treadmill design project
    i want to select the motor that i need
    so i go to calculate the torque that applied on the motor
    i want to know if the weight if the person who use the treadmill is have to take in torque calculations?also the person stand on belt which is over a deck
    that mean the man dont make stress in the belt?
    i dont know if my question is in the right forums, but i hope u can help me..
    and thnks
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Motor torque will have to be great enough to overcome the between the belt and the platform. The friction will be greater if the person is heavier.
    Think of it this way:
    Take a curtain down and drag it across the floor.
    Next, put a small child on the curtain and drag it across the floor again.
    Next, put a man on the curtain and drag it across the floor again.
    Next, put a camel on the curtain and drag it across the floor.
    Friction will also depend on the belt design and the platform design.
    Take the curtain with the child on it and pull it across rocky ground.
    Take the curtain with the child on it and pull it across sand.
    Take the curtain with the child on it and pull it across a fine smooth floor.
    Try it with a burlap curtain, a wool curtain, and a silk curtain.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Do you plan to place many rollers beneath the belt on which the individual is standing as a means of cutting down on the friction of the belt?
    hgmjr
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I have seen a treadmill motor on a surplus site that was rated at one horsepower. that should get you in the ballpark.
  5. h.d
    Oct 22, 2007
    150
    ok sure the weight of the person will effect an increase the friction
    but that is relative to the belt material and note that man not stand on the belt only there are deck(wood) or serial of rollers that carry the belt.
  6. h.d
    Oct 22, 2007
    150
    yes that what i done in my mechanical design
    that rollers i think that will estimate the friction effect
    but the weight of person should effect....but how much that factor is important i want to know?
  7. h.d
    Oct 22, 2007
    150
    the power range is start from 0.75hp to 4hp
    but i have to calculate the wanted power
    i hope my machine able to up person with 80kg
    i want to decrease the hp as can i to decrease the cost of project
    as the power down the current decrease.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Won't rollers on the platform be uncomfortable to the user? And wouldn't each roller have to support the 80Kg of the user?
    And what about us fat people? I'm a full 100Kg. I think I need my treadmill a bit more than some skinny little 80Kg kid! My treadmill can handle persons up to 140Kg. 3Hp motor. The belt has ribs on the inside which slide along a teflon-surfaced platform.
    As with most tools, cutting corners leads to inferior performance.
    And weight does indeed play a role in friction! See my examples above. Or read this: http://en.wikipedia.org/wiki/Normal_force
  9. h.d
    Oct 22, 2007
    150
    we can use platform deck or rollers with the same stability for user,
    about the weight of user,i aim to low power(1.5hp) as able because the high power need larger motor---larger cost----for the motor and in the drive circuit.
    and am not a kid and am 65kg....;)
