Treadmill motor - power loss
Discussion in 'The Projects Forum' started by Elijahwww, Sep 18, 2013.
  1. Elijahwww
    Sep 18, 2013
    I have a treadmill that lost 80% of its power. When i put any load on it (walk on belt), it starts arcing quite a bit and makes noise in proportion with the speed. The motor runs seemingly fine without load at all speeds. At lowest speed I can stall the motor with just a single finger on the belt. But if I rev up the motor to say 50% of its max speed (running speed), I can then do walking pace as the motor labors.
    I took the motor apart and did not find anything apparent. The commutator is a little dark, but i can still tell its copper.The segment partitions are black, very narrow. 0.6mm maybe. Brushes are large, 1.5cm in length still, a little charred on one edge. Winding seems ok, but a little dark in some area. I can't tell if that is from lacquer or what. It never smelled burnt. Reed looks ok too. The motor has permanent magnet, spec sticker states 17.5 A, 145 VDC, 5700 rpm, external fan.
    Both walking and drive belt tension is just above slipping at this point. I wanted to make sure it wasn't tensioning.
    I took the board out, just to give it a visual inspection. I didn't see any resistor charred.
    I could use some suggestions. How do I isolate the problem.
  2. MaxHeadRoom
    Jul 18, 2013
    10,820
    2,494
    First try the motor on the bench using an Automotive battery, if the brushes are off set, it is a Uni-directional motor, so the correct polarity will be needed, otherwise you can test it in both directions.
    Apply a load if at all possible and or see if you can stop it.
    Max.
  3. wayneh
    Sep 9, 2010
    12,365
    3,220
    Measuring current draw might help. I once had a car starter that spun just fine on the bench but wouldn't start the car. Of course this was going on in the depths of winter.
    Turns out one of the two windings was open. The problem was easily revealed by a low current draw - about half of spec.
  4. MaxHeadRoom
    Jul 18, 2013
    10,820
    2,494
    Mmmm...Starter motor is a series wound motor, runs at uncontrolled RPM off load, must have had parallel fields for it to run with one open?
    Max.
  5. wayneh
    Sep 9, 2010
    12,365
    3,220
    Beats me. It was a '67 Barracuda.
    Holding a wrench while laying under the car on my back on an ice patch below 0°F is the part I remember most clearly. That and the aha moment when I finally took it out again and had it tested at the auto parts store.
  6. MaxHeadRoom
    Jul 18, 2013
    10,820
    2,494
    Interesting trivia is that when the idea of a series motor be implemented for car engine starting, it was predicted by many that it would burn out after just a few operations.
    I guess time has proved them wrong!
    Max.
