Good morning! I'm currently working on a lift motor that I'm having issues with. When pushing the up or down arrow to raise/lower the treadmill, the motor will engage, make 1/2 a revolution, then stop. I thought it may be a damaged gear, those look fine. Motor smells fine (not burnt). I can tap on the back of the motor assembly and it will take off. It does the same thing on the bench. The motor is single phase, 120V. There is a capacitor attached, which I am beginning to think is the suspect here, and then the gearbox and lift cylinder. Unfortunately, the identification for the capacitor has worn off. All that is on there is Yuhchang 10% 250VAC. The manufacturer (Jaeger Industrial) has nothing on their website with regards to this assembly. Best I can tell is the date of manufacture was 2004. Their part number is MJ8245. In closing, the motor does operate, just stops under any type load. It has a 1,400lb thrust rating.
Replacement cost is around $325, so if it's something simple I'd like to try to fix it. It also has a rheostat which should have nothing to do with this issue as the rheostat just tells the treadmill what position the cylinder is in.
Thanks in advance, ob_one
