Hi all,
Im a bit of a do it yourselfer but have very little experience with electronics, and the more I googled the more answers from your forum I saw, so hopefully you can help me out!
I have recently picked up a second hand treadmill with an issue (York Challenger 516i, or I believe Healthstream sell the same unit under a different badge). On powering it up the display works correctly, then when trying to start the belt it blows the fuse. The motor doesn't appear to move at all.
If I unplug the motor from the control board it will not blow the fuse, and will give around 330V at the terminals.
If I connect the motor to a car battery it works.
I cant see any components that are obviously visibly faulty.
The photo is only a general overview, I can easily grab more photos of anything in particular.
Any pointers or recommendations would be greatly appreciated!
Cheers all.
Cheers all.
