transpose to 12v
Discussion in 'The Projects Forum' started by happysoul, Oct 12, 2014.
  1. happysoul
    Sep 9, 2014
    28
    Hi Guys and Gals was wondering if someone could transpose this 5volt circuit to 12volts
    thx
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    What is the purpose of the circuit?
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    What is the rated forward voltage of each LED?
  4. happysoul
    Sep 9, 2014
    28
    the forward voltage is 1.8v to 2.1v, the purpose is the led on the base is a flickering led, like a candle but not very bright hence the 1 watter.
  5. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Replace the 620 Ohm with 470 Ohm. Replace the 2 Ohm with 39 Ohm. Use a 2N2907 (or similar) for the PNP.
  6. happysoul
    Sep 9, 2014
    28
    Cool, Thank you Alec I'll give it a whirl, I'll let you know how it went.
  7. wayneh
    Sep 9, 2010
    12,388
    3,244
    The brighter LED should flicker along with the dimmer one, which acts like a controller. Do we know that it works OK at 5V?
  8. happysoul
    Sep 9, 2014
    28
    Yep works perfect on 5v, I tried it with the resistor changes only have a bc327 at home, but doesn't work, the brighter led just stays on, no flicker, maybe the transistor
  9. wayneh
    Sep 9, 2010
    12,388
    3,244
    It's not the transistor (assuming it isn't damaged and you have the pins right). You need to tweak the base resistor to get it to turn the transistor on and off with the flicker. Too small and it's always on, too large and it won't go off.
  10. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Good point, Wayneh. Perhaps try ~1k-2k?
  11. happysoul
    Sep 9, 2014
    28
    Yeah good idea I'll try a pot to get it right, thanks guys
