Transmitting Data to and from embedded device
Discussion in 'General Electronics Chat' started by TheRoman, Sep 15, 2010.
  1. TheRoman
    Jul 22, 2010
    14
    I'm wanting to transmit data ( pictures ), from an embedded device back to my PC and from my PC back to the device at ~50metres, was wondering what the best technology would be to use, was looking for something which wouldnt be to expensive.
    Any ideas?
    Thanks in advance.
  2. Ice-Tea
    Sep 13, 2010
    Speed requirements? If that doesn't matter RS-422 is probably a good candidate.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    What kind of signal does this embedded device normally output?
  4. TheRoman
    Jul 22, 2010
    14
    Thanks for your responses, from reading about the RS-422 this is a line driver transceiver, is this correct? I'm looking for a wireless solution, from what i have been reading it doesn't seem wireless.
    What kind of signal does this embedded device normally output? I'm not completely sure, I’m kind of just getting lots of ideas together and trying to make sense of everything.
  5. TheRoman
    Jul 22, 2010
    14
    Do you know of any cheap bluetooth development kits that are out there? I think this would be a good solution.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    Gotta' know what source of the picture source is in. There are quite a few remote products for extending data, things that pass HDMI remotely may come close but theyll output in that format.
    I mane, have you something like a USB port out you're wanting to extend? You'll need something that can take a compatible input and put out something that's compatible with your PC.
    Bluetooth dvelopment kits? I'm sure there are a few items in fairly raw format but that's just a radio transceiver setup and a low range one at that. You might look through http://www.maxim-ic.com as well as the various RF chip makers websites.
    TheRoman likes this.
