i want to build a wireless system to monitor air pressure. the output from pressure sensor is voltage. so i thought i want to convert the output voltage to frequency by using TC9400 voltage-to-frequency(V/F) converter. then transmit the frequency using a FM transmitter modules. so how?
You would be better off using a micro controller to convert the pressure reading from the sensor using a ADC (Analog to Digital Converter). Then transmit the digital data using a serial protocol.
On the receiver end, another micro controller will display the results from the ADC on a display.
Your coding on the receiver micro controller can convert the digital result to PSI.
If 2.5v = 30psi, the first micro will convert that to say a number=512.
The 512 is transmitted to the receiver via a binary serial protocol over the FM band
The receiver will receive the 512 A look-up table tells it that 512=2.5 that equals 30psi.
The micro then displays it or records it, or both.
ACTUALLY, you could just convert it to PSI in the first micro and transmit that.
