hi i bulit 555 timer circuit running at 100khz square wave driving the gate through a 10 ohm resistor the with source connected to ground i want antenna connected at the drain and want apply 12 volts to the drain but i want to limit the through the drain to 6 amps or 72 watts how is this normally achived as a 10watt resistor would burn up
